No display GTX260
12 Dec 2005
I purhased a GTX260 recently from the MM, slotted it in the mobo, made sure both PCI-e connectors were connected but when I turn my PC on I get no display on my monitor.
Mobo is ga-965p-ds3
Using latest bios.
Any advice?
Cheers
Psu is ocz 500w modular so should be fine.
Can't see any display at all.
I tried the card in my brothers PC.using the psu of mine and it was fine.
Seems to be my mobo that's the issue...how can I be sure?
any jumper will do, you dont need any power, infact you should unplug the power cable while doing it.
I've just tried that and no difference at all.
The mobo was working fine before I put the GTX260 in it, but the GTX260 and my PSU work fine in my brothers PC.
The 260 is a bigger card, it kind of feels like it isn't being pushed into the GPU slot all the way at the front end but it must be because it clicks in to place and also my brothers 8800GTS doesn't work in my mobo at all...
Cheers
take power lead out hold power button for 10 secs then take battery out wait 10 mins to an hour also take card out and blow on pci express for dust
Tried all of that mate. Just don't understand it was fine with a different gpu yesterday.
Also you could try take card out and power up with out GTX260 in see if you get error beep
Probably a dead mobo now :( could have been a build up of static and when components were moved it shorted something...Just my guess.
