No Display on BF3
Permabanned
14 Apr 2012
Hiya guys just installed my new I5 3570K, Z77 board, 670 X3, I installed BF3 (the reason for the upgrade) have installed all of the patches, I select a server it loads, states it's "Playing!" it launches me into the game, I hear the sound but I just have a black screen extremely odd.
Anyone have any idea's?
I've reinstalled it 3-4 times.
It wouldn't have anything to do with having windows on SSD and origin and BF3 on HDD.
No. A lot of people run like that.
I run with Origin on the HDD but BF3 on the SSD and it works fine so I don't think this is your issue.
I bought a Russian key as it was cheaper, I installed it for 10 hours it all worked however it was in Russian there is a way to convert it to english I did all of that but the game wouldn't even load then. So I realised my brother had a BF3 Limited edition disc so I just installed it off of that.
When you click to join a server and the game starts to load up, untick the 'goto game when ready' and leave it for 2 mins loading, then click on the BF3 program running in the task bar to maximise the game and see if that works. Mine sometimes does this when loading maps so i ALT TAB out of the game to the desktop and then go back to the game when i hear gunfire.
Might be a pain but it might get you playing for now.
Also it could be a problem with punkbuster, it might be worth uninstalling and re-downloading punkbuster.
hi guys,
iv heard the russain can be changed to a english pack so there probably is definetly no error on that behalf. make sure you have the latest drivers mate. :)
It happens whenever the game patches itself. You will need to get the latest language patch from cjskeys.
I can imagine it would have an issue using the BF3 Limited Edition installation instead of Russian.. Either way, it's not a graphics issue, this happens when it doesn't have or can't find the correct language files.
