No display on Computer
24 Apr 2010
So, first of all sorry if this has been posted before.
Ok so i turn my computer on, i can feel and see the fans going on both my CPU fan and my GFX card fan i can hear the CD drive and the harddrive working but i have no display. I have tried swapping the monitors etc.. But still no use, so i'm guessing something has broken. Just need one of you fellas to tell me what it is
Willing to try things out if it will help find whats wrong.
Thanks in advance - Jake.
- I also don't hear that beep you usaully hear when you turn a computer on if that helps.
ACER
Processor:
Intel(R) Core(TM)2 Duo CPU E4700 @ 2.60GHz (2 CPUs), ~2.6GHz
Memory:
3070MB RAM
Hard Drive:
629 GB
Video Card:
NVIDIA GeForce GTS 250
and i have a 750w powersupply.
I want to try find out the problem so i can start to think about buying a new part for it.
I think the first thing you need to do is check that the power supply is supplying good stable voltages.. You can use my guide here to help.
http://www.huddysworld.co.uk/index....rking&catid=40:techie-talk-hardware&Itemid=72
Now that you have eliminated the Graphics card, PSu and monitor, it has to be either the Motherboard or CPU. The fact you get no POST beep suggests the mobo and that's where my money is on if it isn't the PSU.
This happened to me once about a year back and someone said to switch everything off then make sure monitor is turned on as normal, reboot the tower unit and wait until you feel everything has loaded then still leaving monitor on pull out the power plug from socket for monitor only, wait a few seconds and replug back in. I don't know why but it worked and has never given me a problem since. Worth a try anyway. Good luck. :)
Yeah, i think if i did it all right my PSU should be fine. Looking like its a new MOBO.
This also didn't work i've come to the conclusion that its my motherboard thats ****ed.
