Caporegime
- 12 Mar 2009
I have a bit of an odd problem and I'm hoping someone can give me a bit of help. (PC related)
Basically I'm not getting any picture either through my on board graphics chip or via a PCI-e card. I've tried my motherboard's built in Geforce 9300 and I've tried my HD5850. The motherboard has VGA and HDMI so I tried HDMI first, plugged into my HDTV and nothing, then I tried my graphics card over HDMI and nothing. So I pulled my Samsung LCD monitor out and connected the graphics card via DVI, nothing, I then tried the on board via DVI and nothing again.
The weirdness is that this computer has worked fine in the past, the computer turns on, all the fans spin up as they should, as per normal, the power light comes on, and all looks as if it should just there's no picture either on the TV or on the monitor. I thought maybe the graphics card could be at fault (even though it appears to power up and spin its' fan) so I removed that from the equation by taking it out of the PCI-e slot but still there's no video output. Can anybody give me some advice?
So far I've tried:
What else can I do? I don't think it's the motherboard at fault as the lights all come on, on the the motherboard and the case fan, the GPU fan and the CPU fan all spin up as well as the PSU fan.
Motherboard is a Zotac 9300 ITX.
Thanks.
So far I've tried:
- Removing the graphics card and using the on board graphics chip
- Unplugging and re-inserting the motherboard power cable from the PSU to the motherboard
- Resetting BIOS by taking the battery off the motherboard and waiting a few moments before re inserting it
- Reseating the RAM
Thanks.
Booted into Windows with the onboard graphics, installed the Catalyst drivers for the 5850, disabled the Nvidia 9300 which is on my mobo and it automatically picked up the 5850.
