i5 3570KSpecs?
Is there any activity from the PC? any fans spinning, any lights ON?
Does the GFX card need extra power from the PSU?
When you plugged the display into the motherboard, remove the GFX card.
i5 3570K
Gigabyte Z77 D3H motherboard
MSI HD 7850
550W OCZ PSU
Zalman Z9 Plus case
Everything comes on, fan controller, fans and the front lights
i5 3570K
MSI HD 7850
550W OCZ PSU
Zalman Z9 Plus case
DVI from motherboard to DVI monitorRemove the GFX card and connect the display to the board, does it work then? if so, update the BIOS. (do this first if you can get a display without the GFX card)
Are you using a DVI-VGA adapter to connect to the monitor?
I'll give it a try tomorrow, I want to overclock my CPU, but I don't know how to,So have you tried with the GFX card removed or not yet?
http://forums.overclockers.co.uk/showthread.php?t=18448187
Can you be a bit more specific, as this build goes back to July.
So, what have you done prior to this occurring?
Hope it's not an old build, the OP in the first post says it's new.![]()
Your Avatar threw me off for a minute. Thought we had another Stulid.![]()
I've removed graphics card and plug in DVI from motherboard to DVI monitor and still no displayA lot of people have been having problems with Z77 D3H.
Remove GFX, and see if you can boot with onboard (if so, update BIOS).
The monitor is working on my other computerhi^^
no chance the screen is at fault?
