- 6 Jan 2021
Hi folks, please help me before I have a nervous breakdown! Ill try and give as much detail as I can, so apologies in advance for the lengthy post...
Couple of days before xmas, pc working fine, no hardware or software issues, couple of hours of Warzone, then shut it down for the night...next day tried to boot up but getting no display error on monitor. Pc seemed to be coming to life, all fans and lights kicking in, but no signal.
Checked all cables, connections , etc - nothing. tried different cables, display port, hdmi and different monitors - nothing.
PC specs -
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card
GX-352-AS
Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - OEM
Asus Maximus VII Ranger Intel Z97 (Socket 1150) DDR3 ATX Motherboard
MB-611-AS
Antec 902 Nine Hundred Two (V3) Ultimate Gaming Case (with USB3.0 Support) - Black
CA-110-AN
Antec EDGE 650w 80 Plus Gold Fully Modular Power Supply
CA-231-AN
Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit (CMY8GX3M2A2400C11R)
MY-382-CS
This was all purchased from OC about 6 years ago, so I figured its getting to that time where things are gonna start to fail, probably my gfx card has finally given up on me....not the best time to get a new gfx card, but hey ho....
tried a different gfx card - nothing
power supply maybe? took that to my local pc shop - tested and they said its all ok
took the whole pc to the shop, they tested everything but the cpu and mobo - couldnt find the problem, so they were pretty confident it was the motherboard had died on me
So bit the bullet and ordered new motherboard, cpu and ram from OC , new specs -
Asus ROG Strix B550-F Gaming (Wi-Fi) (AMD AM4) B550 ATX Motherboard
MB-6FC-AS
AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail
CP-3B7-AM
Corsair Vengeance LPX Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
MY-4BW-CS
Kept the same gfx card for now, money too tight and gfx cards to thin on the ground.....still the same problem!!
Still getting no signal at all, tried directly from motherboard to bypass graphics card - nothing.
also tried disconnected the ssd's, but made no difference either way
Im now a big chunk of change down, and the thing is gonna cause me to have a breakdown if I don't figure it out soon, any suggestions please???
PC specs -
GX-352-AS
MB-611-AS
CA-110-AN
CA-231-AN
MY-382-CS
MB-6FC-AS
CP-3B7-AM
MY-4BW-CS
