No Displayport signal on new 5700XT.
5 Oct 2004
Notts
I’ve just built my new Ryzen PC and the HDMI works fine but I can’t get anything from any of the 3 Displayports.
Anyone had this problem. I’m using the standard cables that cane with The monitors. Thanks.
Has the displayport cable ever worked?
If you have another DP cable, or device that outputs on DP it may be worth testing that.
So the issue is the monitors I'm using. They're Dell 24" with 2 X DP, 1 X Mini DP and 1 X HDMI. It turns out that the second DP doesn't work and seems to be a dummy port. In the menu there's no option for DP2 so originally I thought it auto detected but no, it's just not connected.
It's probably an output rather than an input. My old Dell monitor (a U2414H) allowed daisy chaining via DisplayPort.
