After some cleaning and little bit of cable management work inside the case I have a problem with my monitor. It says that there is no DVI-D signal.
1. I tried different cable (D-Sub with DVI switch).
2. I tried different graphic card - no luck.
3. I tried whole system with another monitor - no luck
4. I tried my graphic card with other system - working ok
Any ideas what else I can do. At the moment I thinking maybe motherboard but everything seems working fine except I don't have a picture. I'll welcome any advice. Thanks
