No fans included with the akasa eclipse?
flunky404 said:
No you don't get any fans with the case.
I put a couple of akasa ambers in mine it's a great case :D
Agreed. Great fans, got them in my Akasa Eclipse, although a little noisy at 12v. ;)
VeNT said:
mirage is better than the eclipse
and iirc slightly cheaper (about £4 less)
I thought the only difference was front panel? Although Ive heard something about a different side panel? :confused:
Just the front unless its changed since release. :)
Get the cheapest one, the Eclipse has shot up in price recently due to stock shortages so it is a little bit pricey at the moment.
On the door : They put the wiring for the power/reset/hdd on the actual door of the mirage (the eclipse has it on the frame), so when removing the door to add a fan for example, you have to route the cables through the front of the case. Pain in the ass.
On the exernal connectors : The Mirage has 2 usb, audio and a firewire connector on the right side. The firewire is crap though as it has no mobo connector. It's an external job, so you either route it out the back of a pci slot and connect it externally or find an adaptor to connect it to your motherboard.
On the pci slot on the front : gone from the Mirage. pants. it was useful for say a fan controller for a tuniq tower.
On the quality of the door : crap...it marks easily, and even though it has vents, airflow is slightly impeded over the Eclipse (maybe 1 or 2 degrees at most for system temps).
Other things : the wireguide inside the mirage is black to match the rest of the case. the eclipse (except on recent models) is a different colour.
Also, for some reason my HD lead is permanently on.
The sidepanel you mentioned is the optional thermally advanced panel and useful for cooling the hot spot over your gpu. It fits on the Eclipse and Mirage though of the 3 or 4 I have seen sometimes the panel gaps are poor and you don't get a great fit. The panel actually can rattle a bit when you touch it. Luckily I got a good 'un.
Kinda weird that you get 2 120mm akasa fans with the akasa zen but not with the eclipse. Especially when the zen is £32 and the eclipse is £100 :confused:
Bought the eclipse as im not too keen on front panel doors. The computer will be next to my monitor so opening the door will be a pain.I like the look of the eclipse over the mirage anyway.
Just be careful with the front cover. I've broken two of the three plastic clips on the left side now. Makes it easier to remove I suppose. :p
