no gpu output?
Permabanned
26 Jul 2007
Coventry
no gpu output?
I've just built the PC in my sig.
I've hooked up the screen and i'm not getting anything appearing. It's saying it has no signal (the led stays orange on the screeen)
thanks guys :mad::confused::eek::(
Does the BIOS POST? Do the Fans and Hard Drives Start up? Is there an LED on the Motherboard lit up?
If yes to all of them make sure the Graphics Card is seated propperley and that it has power.
don't worry it's done now, thanks anyway.
I had forgot to plug in one of the small power cables to the mobo.
Now it's saying one of the windows files is corrupt :confused:
