No GPU recognised or Bois setting does anything ASRock B650E PG-ITX WIFI with SAPPHIRE NITRO+ AMD Radeon™ RX 7800 XT
Mad
Mad
22 Aug 2014
Hi guys
I bought a
No signal to TV have tried both hdmi sockets been through the Bois external graphics. I put in a gt740 card it worked off the pci slot no worries. I don't get anything from the 7800. Updated the bios to 3:15
I'm really thinking of buying a matx board .
This pc
ASRock B650E PG-ITX WIFI SAPPHIRE NITRO+ AMD Radeon™ RX 7800 XT
AMD Ryzen 9 7900X​
Corsair Dominator Platinum RGB 64GB (2X32GB) DDR5 PC5-41600C40 5200MHz Dual Channel Kit - Black​
Any help be much appreciated
Hi.
Merry Xmas and welcome to the forums.
What PSU have you got?
If you are using 1 power cable to the GPU, try with 2 seperate ones. Daisy chaining off 1 cable can sometimes cause problems.
Hi guys
Thank you
PSU is a
Silverstone SX1000R 1000w PSU PCIe 5.0 Cybenetics Platinum Modular SFX-L Power Supply
Yes tomorrow Im swapping out a 3060 ti
And hope to use the 7800XT on a
Gigabyte Z590 VISION G motherboard.
Hi.
Yes just tried this 2 pcievpower cables still nothing. Will be doing the motherboard swap today. Thank you
Good luck.
Was going to suggest a bios update as that sometimes helps, but you have already done this.
It's a puzzling time... I saw a jays2cents video once same type deal no picture from GPU it was a GPU firmware update... Il have to look that video up again. Thank you bud
It could be that there is a setting in the bios for which PCIE version you want to use is set incorrectly as the GT470 is Pcie 3 and the 7800XT is Pcie4. If there is this setting you may need to change it to Auto
Il try that thanks.
I tried the 3060ti and it booted on the board ,tried the 7800xt on the gigabyte board it's still the same no picture.
Just seen there is a bios switch on the GPU.
Does it work if you switch bios? (power off the PC before using the switch)
Hi thank you I went through each setting after a shutdown still nothing. Asked for an rma.
Thanks for the help on this guy's I'm tapping out
The bios switch was a long shot, but think it needed ruling out.
Good luck with the RMA, hope they don't keep you waiting to long.
