no GPU work for GPUGRID ?
Poem@home has just started a new batch of GPU work units. Not sure about the availability of the WUs, I know in the past you had to constantly request work.
Gave up with folding again. I have poem and gpugrid running whenever they get work.
I seem to have broken something as my cards won't go to full speed when they do have something to do:-(
I had to use an app_info.xml to get poem to max out my gpus, by the looks of it though it seems the new poem work units are quite buggy, many crapping out with computation errors.
My cards are nowhere near maxed; hanluc, can you share the app_info.xml you created? I'm wasting so much of the cards' capabilities compared to other DC programs :(
Is this for GPUGrid? the app_info.xml I have for for poem@home AMD cards. Quick google has come up with this 2nd post down. It's fairly old so you may need to update the .dll names if they changed since, also make sure you have finished any existing GPUGrid work before adding it as it can wipe out existing work.
