- 30 Sep 2024
- London
On a Gigabyte B450M S2H, I lost HDMI output where it was previously working.
Symptoms:
Following Dr Google's suggestions, I tried:
None of these make any difference. I'd welcome any suggestions what I can do further to diagnose this issue.
Thank you very much!
Symptoms:
- No HDMI input on the monitor (but the passive cable connection is detected)
- Power is present
- CPU and case fans are spinning up
- Secondary SATA HD is spinning up with normal noises
- Connect the HDMI cable to a different computer's HDMI output - works (so it's not a screen or HDMI cable issue)
- Remove the CMOS battery for 30sec
- Remove graphics card to force fallback to built-in motherboard graphics
