No hot water
17 Aug 2009
Finchley, London
Stand down chaps, all fixed, just thought I'd post about it. Few weeks ago I had F54 and F28 error codes on my Vaillant boiler, saying ignition unsuccessful. I was able to reset it by turning the boiler off and on and then pressing the spark ignite reset button. Last night same error codes but I couldn't get it to fire this time, nor this morning. It will show on screen that it attempts to ignite it a few times and then it goes back to the error codes. No hot water, arrgh! You realise even more how important it is to have hot water when it's not there. You can't really do much without it.
I called the gas engineer that installed my central heating system 8 years ago, he laid all the pipes and installed the boiler (did a good job) and he was going to come round today. On the phone, he reckoned it would be some lead or the pcb. I thought it might be a dirty electrode not sparking.
Meanwhile, another engineer recommended to me that I'd left a message with earlier this morning called me back and came round straight away. He specialises in Vaillant and from me saying I was once able to reset it he said it'll almost definitely be the gas valve. He replaced the gas valve and it's all working perfectly now. £160 for the valve and charged £90 for his time. Only at my house for 20 minutes. We're in the wrong job!
But if the other guy had come to replace the pcb, it would have been a lot more expensive. Funny how two gas safe engineers can come up with two completely different diagnosis. But clearly it didn't need a pcb.
I have the same issue issue with my Vaillant Combi boiler, I have managed to get it going, happened twice so far.
I was looking at the the video below to see what the fault codes were at the time.
How did you get yours going, did you turn it off and on or just press the button with the flame icon?
Sometimes works out better ringing the manufacturer direct as they normally offer a fixed price repair and would replace everything needed, so could get a gas valve mainboard and pump for a one off price
First time I did a few resets and kept changing between hot water and heating and managed to get it going.
2 weeks ago I ended up turning the gas off tried to start the boiler to see if the valve was opening (gas pressure had dropped as I tried the gas hob) went upstairs and took the cover off to see if it was Igniting and the thing started.
Vaillant ecotec 838 plus.
It turned off during the day with F28 code. Checked outside and the condensing pipe was frozen. Broke it off and a lot of water came out with bits of ice too. Turned boiler on again resetted it, stays on for few mins makes 3 loud thumping noises then gies iff again, same problem but this time with an F54 code too.
Do i need to call someone out or shall i wait till temp goes back up abit.
Anyone else having issues with boiler in this big freeze?
Boiler is only 3 years old but no warranty as i forgot to get the certificate and register it in time
I've just experienced this myself. Simply tapping the gas valve with a small rubber hammer worked a treat (without needing to replace the GV). How long this lasts for I don't know but a comment suggests it could resolve for a good while before replacement needed. I hope this YT vid helps someone else...
