No input signal
28 Aug 2009
Okay so I received Titan Nero went to hook it all up turned on and screen displays "No input signal" the monitor is a HP w1907s. Couple of things I'm using VGA cable don't have the DVI cable. Computer turns on fine fans running mobo beeps just wont display a signal...Help much needed.
Thank you
Well I am assuming your graphics card has two outputs -> try the other one.
I am also presuming that the card has two DVI outputs as it is a modern card, hence you have a DVI->VGA adaptor?
Erm I'm running the VGA cable from the monitor into the mobo as I dont have a DVI cable (I'm complete dimbo at this). The desktop was built by OCuk so I have limited knowledge of whats going on in the inside. Do you mean I need a DVI cable?
