No Internet on desktop,, wifi is ok though.
3 Oct 2013
My desktop has now got no network connection, I have tried several reboots of pc and router, changed cables but no difference
http://i236.photobucket.com/albums/ff103/seankeggers/655037ff932c49eb4758a04750e8bfd4.jpg
My pc is on windows 7 wired connection
ISP is aol now talk talk I believe
My modem is a huawei echo life hg532
Anti virus is avg
Firewall is windows
I'm hoping someone can assist with getting me back on the net as I use the pc for working from home..
Thankyou.
Have you got more then one ethernet port on your router? If so I'm guessing you've tried in a new port?
Reinstall your ethernet drivers. Will be on your Mobo disc?
Been into internet settings and made sure its on automatically detect.
Internet settings > connections> lan settings.
Your motherboard disc is different to your system repair disc,
One thing I would try is downloading winsock fix and running that on your pc.
I would check if your network adaptor is disabled.
Go to Control Panel > Network and Sharing Centre > Change Adaptor Settings.
Is the Local Area Connection disabled? If so then right click and enable it.
