Hi all,
I just got an Audigy 4 after using onboard sound on my mobo. I'm pretty impressed with it but as it was OEM, i didn't get a manual with it and therefore don't know which connectors are which. So during games i get sounds missing as i've just guessed which sockets are which
I've set up the software to 5.1 sound if that helps.
The manual that was included on the cd doesn't display the page that i need (see below) either if i install the manual from the cd or from their website.
I want to connect up my 5.1 Speedlink Medusa's to the soundcard and then my 2.1 speakers to the speedlink amp.
Thanks
Thanks
