No monitor display...
30 May 2012
So I've put together my new build, it all works very well until I plug in the graphics card (KFA2 GTX670).
I'm using a DVI connector to a Benq XL2420T, and it works fine unless I have the graphics card in. If I do, then I get no signal on either the motherboard output or the gpu output. The fans spin on the card, but the monitor just says no signal.
My specs are:
intel i5-3570k
corsair vengeance 8gb
gigabyte z77x-d3h
seasonic x760w
2xSSDs, 1x HDD
Any ideas?
Well I've tried the latest BIOS and still no response from the card, the fans are spinning and it's got power... in the BIOS there's something called 'PEG Gen 3 Slot Configuration' at the moment it's set to auto, do I need to change that?
You shouldn't need to. Mine is left on auto.
Have you tried connecting to the other DVI port? I've noticed the GTX670 can be a bit finicky and refuse to output on boot to one of the ports.
Try and use just the absolute basics (single stick of RAM, no drives, nothing else apart from mouse/keyboard plugged in etc)
Done this, and it works :) Thanks so much to both of you for helping me out, it was such a great feeling when it came up :D
Thanks again :)
