Windows 11 24H2 New requirement cannot be bypassed as the OS will use instruction sets of CPU
There is a difference in removing the check for minimum requirements and the Operating System using a set of instructions that is needed in operations
No bypass
Yet
Doesn't mean some clever person won't make one
This does look to be harder
Than previous bypasses to be fair
I am ok my CPU came out 2018. |
You have a choiceewaste. most people are just using their home computers as netflix and word document machines, not storing government secrets on them.
the user should be given a choice.
Don’t think my other system with an i7-4770k + Z87 motherboard support windows 11 from what I can rememberHonestly, if you're using an unsupported CPU, there's a good chance it's over 15 years old at this point, in which case I don't see the argument against this.
Totally agree with you and imo this is the reason behind it as PC,s last a lot longer now.Annoying I'd need to upgrade two of our three PCs, that's a lot of cost. It's not the licensing cost that's the problem, I'd be binning a lot of perfectly functional hardware to do it.
