No Mouse and Keyboard detected in Vista after AMD Cat removal
26 Dec 2003
North Wales
Guys ...... i need your help badly
After removing AMD Catalyst drivers 11.9 using the remove all option, i rebooted back to Vista but had no USB Support, every usb ports have gone down, so now have no mouse and keyboard support .. grrr
I know they still work as i can go round the BIOS screen and i have even installed Vista on another drive where my keyboard and mouse does work there but my main drive i cannot use with no usb support, i do not wanna format it as i have all my work on it and just want to know is there any way i can get drivers off the newly formated drive and transfer them over or is there a driver package that i can download and install from my new drive to the other drive ?
by any chance is your system AMD based? it's likely that where you've removed the drivers, it's taken other AMD drivers too (namely chipset/usb etc).
when you boot back into windows, does it run the windows driver-finding thingy? if so, let it run and reboot, then hopefully they'll come back after.
if not, safe mode and roll back to a restore point before you took off the catalyst software.
