No net connection, but on network?
18 Oct 2002
Kuala Lumpur, Malaysia
Tried to get into one of the office PCs today via Logmein and was suprised to see it offline,
So I RDPed into another machine on the same local network , and I can RDP into said machine from there - however it doesn't seem to have an internet connection :confused: I've tried rebooting and that didn't seem to make a difference
Just on a simple network going through a router, no changes have been made and other machines are online .
Any ideas how I can diagnose/resolve this, preferably without having to go into the office :p
This PC has XP pro on it, was working fine on Friday
What was the problem. Mine does this every time i boot up. Local connection only. Does my head in. I have to disable and then enable the network connection in device manager to get it to fully connect (local and internet). Since puting on windows 7 too.
Interesting thread here.
I use logmein to get to my PC at home from work. Using W7 on both machines. Since around 1 week ago Logmein seems very tempremental. I can see my PC online in my account area, but when I connect it tells me it's "waiting for computername" then times out.
It's not a problem with the work firewall as I have tested it by allowing all traffic in/out from my IP for a short period. It seems very much an issue with my home PC.
I know my PC was on this morning and logmein was enabled. Knowing about this problem I even went to the login page from my home PC and it worked fine...
Oh, and its temperamental too! Yesterday it worked fine, today it's not working at all.
I think I'm going to uninstall the software tonight and re-install it as I'm nearly 100% confident the problem is at my end!
That PC was set to static IP instead of DHCP , the local DNS server that was pointing to was turned off, so net wouldn't work, hence why I could only RDP in using IP from another local machine :)
