- 28 May 2018
So I’ve just done putting together a pc for my brother. Everything was fine and it turned on first try, we used his SSD from his old computer.
The problem is is that it won’t connect with a wired Ethernet connection, there is no network adaptor listed in device manager and attempting to install Realtek Ethernet controller gives the message “the Realtek network controller was not found, if deep sleep mode is enabled please plug in cable”
I have no idea how to fix this, I’ve looked online without any success. it just seems like there is no network adapter and I don’t know what the root cause of that is. We’ve tried loads to troubleshoot it but I’ve really run out of ideas. I’ve tried to install all sorts of drivers, used windows reset, checked for hidden devices in the manager, updated the bios even. There are other things but I’ve been doing this for five hours now so I’m tired and at my wits end and hoping someone on here might be able to help.
Obviously the motherboard comes with an Ethernet slot I just need to know if I need it install something, fiddle with it or if I need a replacement. Thanks.
mid you need more info let me know.
Also I don’t have a windows install disc
OS: Windows 10 64bit
motherboard: ASRock b450m pro4-f
CPU: Ryzen 5 3600x
GPU: Radeon 5700 xt
RAM: 2X8gb Corsair LPX @ 3200mhz
SSD: Samsung evo 860 1TB
CPU: Ryzen 5 3600x
GPU: Radeon 5700 xt
