No networking on Ubuntu 6.10
29 May 2005
Lazenby near Redcar
I have installed Ubuntu 6.10 AMD64 on an Opteron based PC and Im having problems getting the network up and running.
The install went smoothly and I checked that the network connection was working and it was.
I was about to set up a new user when an info bubble popped up and asked if I wanted to download and install the new updates.
I clicked on the update icon and it downloaded and installed the updates and asked me to click on the update icon to restart. I clicked OK to restart and when it opened back into the desktop I tried to connect to the network it couldnt.
I did write down the network settings before updating but if I try to use these I still cant connect.
The PC is connected through a router as are all my other PCs running XP.
can you also cat /etc/resolv.conf and post contents up here, also dmesg output. dmesg >dmesg.txt will give you a txt file in the current directory.
cheers
deano
You might also want to try pinging your router or pinging your Ubuntu machine from another machine on the network. That would indicate what sort of problem you have if the ping is successful yet you still can't connect to the Internet.
ifconfig gives me the following:
eth0 Link encap:Ethernet HWaddr 00:01:29:D5:19:DC
UP BROARDCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes;0 (0.0 b) TX bytes:0 (0.0 b)
Interrupt:209 Base address:0x2000
lo Link encap:Local Loopback
inet addr:127.0.01 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:1142 errors:0 dropped:0 overruns:0 frame:0
TX packets:1142 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:57100 (55.7 Kib) TX bytes:57100 (55.7 Kib)
It should be a capital d where the smilies are. :confused:
Woot!
Now, on to finstalling. :D :D
I recommend you set a static IP and install SSH right off the bat so you can remotely administer the macine from any other machine, including one running Windows. It makes it handier to monitor a farm that way.
BillytheImpaler said:
Woot!
Not quite there yet!
I tried a reboot (just incase when running F@H) and the network failed again.
using the command sudo /etc/init.d/networking restart has got it working again but as you know it needs to work all the time.
Would setting a static IP address solve this?
And what IP address should I set?
Soz for being a noob at this. :)
Heck if I know. It can't hurt to try. :o
I usually set the static IP to be the same as the one DHCP gave it. If you're in Gnome open up System >> Administration >> Network Tools and find your IP address. Then open up System >> Administration >> Networking and click Properties for your Wired connection and set the information. Reboot and see if it works.
My IP Information is:
IPv4 127.0.0.1 255.0.0.0
IPv6 ::1 128 Host
The second one is highlit.
Not sure which one to use.
That's your loopback IP. You need to change the Network device drop-down to Ethernet interface to see the status of that Ethernet interface. ;)
EDIT: Yes that is normal. :)
i would recommend using an IP that is not in your DHCP range, to avoid problems later on.
cheers
deano
If I set it to static entering the following IP: (this is the IP shown with eth0)
IP 192.168.1.107
Subnet mask 255.255.255.0
the connection dosent work.
Do I need to enter a Gateway address aswell, if so would this be the routers name.
