No Nonsense Mould & Mildew cleaner
17 Aug 2009
Finchley, London
Quick question guys. Just on my way to Screwfix to pick up some things. I normally use HG Mould remover but have run out of it. They have this No Nonsense Mould & Mildew remover cleaner, 1Kg for £4.99. Anyone tried it, is it good? I believe it's non bleaching. Or do I buy another HG Mould remover which is £5 for 500g.
Not to worry, bought the No Nonsense.
I'd be interested to see if there's any difference in these products as I usually use the HG Mold spray - cheers
I haven't used it yet but it doesn't smell of anything, maybe a bit like washing up liquid. Apparently it doesn't use any bleaching agent which HG does. I kind of think it probably won't be much good but I'll update.
Always use HG myself, from a quick Google it seems the diluted bleach and industrial cleaner in the HG might be the better remove but the benzalkonium chloride in the No nonsense a better long term preventer. But that could all be cobblers.
