No OC Scanner in AB?
Permabanned
3 Nov 2018
The other side of The Gap
I have a 1070, is it possible to use the AB OC scan?
I enable everything core voltage etc but the scan button in the curve graph doesn't appear.
Ctrl+F should do it. Otherwise you need to run AB with the MSI Cyborg Red skin and the button for the OC scanner will appear on the top left of the UI IIRC.
Just tried, ctrl +F brings up the curve that I was already getting, problem is the OC button isn't there. Also tried the Cyborg Red skin and no button anywhere.
Some handy tips with Afterburner Beta and OC Scanner:
Startup, i.e. auto-enabling the profile you want on startup, won't work with profiles locked. It will default to stock profile.
Hit L on the keyboard after selecting a point on the OC Scanner curve, to lock voltage and frequency to that point. Very useful in choosing a max frequency/max voltage and auto-levelling off everything to the right. Hit L again to unlock.
Holding CTRL down + click on the OC Scanner "Scan" button recovers the last scan's curve. Useful in case things change when you actually apply it in Afterburner.
If you apply the scanner curve to Afterburner at a different temperature to the max temp reached by the scan, the curve will change drastically.
OC Scanner gave my 1070 (EVGA SC) better curves* with Power Limit set to 85%/90% (later I pushed it to 105% PL to help the 1.0v @ 2025MHz OC have all the power it needed in benches/games).
* Higher frequencies at lower voltages. Not necessarily the highest frequencies at high voltages.
