No operating system
Permabanned
27 May 2007
London
:mad:Ran a disk check on my PC last night came up saying disk has errors needs reboot to complete repairs.
on reboot came up with no system found, PC is ruining on raid 0 ..ANY ADVICE
System when it was available was/is Win 7 64 bit :(
One disk may be scrap. If you have another PC take the disks out and test them individually. RAID 0 is no good for redundancy, so all may be lost :(
Seems the PC can not see the hard drives, losT its raid, any advice, I really need to get back in if only to recover some files then do a full system re-install
has bios altered the hdd config? ie reset form raid to ide? this would mean comp wasnt able to see hdd's
You know I built this systems, have taken it apart about 8 times I know it back to front and you dare give me such simple advice ......:p and be right:o ..ffs how stupid can I be ..cheers m8 tis all back now :).
Cheers again for the help :)
Thought you were going for a King Size "throw the toys out the pram" when I started to read your reply.... lol
Glad you've got it sorted :)
