No option for 144hz.
31 Dec 2014
Hi All.
I have 3 monitors hooked up to my pc.
One asus via hdmi
2x aoc 144hz monitors via mdp>dp.
Only one of the aoc monitors is giving me the option of 144hz on amd catalyst control center and also windows control panel.
any idea?
Thanks
Using a 7970 GPU
switched on aoc monitor to dvi-d and that is now 144hz. the other 144hz i am using mdp>dvi-d and that is still 60z and no option to change. strange this
don't you have to be careful with what ports you use on the AMD cards as some of them share bandwidth?
For some, when using DP you end up needing an active adapter?
