Hi,
I was using my pc this morning for gaming when both of my screens lost signal, the game was still running in the background with audio etc.
I reset the PC assuming it had a funny 5 minutes but still no signal.
I swapped out a HDMI cable from the gpu to the motherboard display and that worked as normal, so assume it’s a GPU related issue.
I factory reset the GPU to see if that would help but still no signal.
A few details
Gpu - Sapphire Radeon RX 7900 XT Nitro+ Vapor-X 20GB GDDR6 PCI-Express Graphics Card
Motherboard - Asus TUF Gaming B650-Plus WIFI (Socket AM5) DDR5 ATX Motherboard
PSU - Corsair RMx Series RM750x 80 PLUS Gold Fully Modular ATX Power Supply (CP-9020199-UK)
All bought new Nov 2023
No issues at all up to this point, only things to note are sometimes my PC enters bios as the boot sequence seems to get lost? And a few days ago the monitor display had some “lines” at the bottom but this went away on its own after a few minutes.
I assume this is a hardware issue relating to the GPU as everything else performs as normal. Another thing to note is the GPU appears in the AMD software with temps, utilisation etc but no output to the screens
I believe I am in the warranty window with overclockers but would like to resolve this or at least understand what happens before fixing it.
All advice is appreciated.
Thanks
Chris
A few details
Thanks
Chris
