Try resetting CMOS via either the battery or jumper if there is one.
if the PC powers up etc it sounds like it may have friend the GPU.
try the clear cmos but then try a different output port on the gpu, check gpu power cables and try a re seat of the gpu as well.
if he has a on board gpu try that or if you have a spare gpu take it with you to rule it out
Depends on what is the cause of the "no output". If the motherboard is fried then the probability of your GPU frying if you plug into it is quite high. If it's just a case of the PSU has given up the ghost, then you won't do any damage. Good luck![]()
Before trying graphic cards, I'd want to try another monitor. It's possible the monitor has just blown a fuse.
I had this same problem with my computer after the storms, I just turned everything off at the plug for 20 minutes and then it all worked fine. Not sure what caused it though.
