Hello, i'm struggling to use my TV or a monitor as a second screen to my MSIGT62VR laptop with a 1070.
It used to work fine but now on whatever monitor I plug it into I get a "no signal" message. I have tried 2 standard monitors and 1 x Sony 4K HD TV. As well as this I have tried 5 different HDMI cables. I know the cables and the ports on the monitors/TV are serviceable as my PS4 and partners laptop work with these ports/cables.
I've done all the standard stuff regarding the windows and Nvidia settings. I've done hours and hours of googling but unfortunately nothing seems to help. The Nvidia control panel does see the display, but unfortunately no output - tried all resolutions/refresh rates etc etc.
I have updated the BIOS/EC and Nvidia drivers. Unfortunately its still the same. I have discovered that if I set the display from the HDMI port on the laptop to 800x600 then I DO get a picture on the screen, although its a tiny 800x600. Any resolution other than the one stated just gives me a blank screen with writing along the lines of "No signal, check the external input". This is on a 2017 Sony Bravia 4k TV, which i've confirmed all the HDMI ports work up to 1080p.
Under NVIDIA settings it can see the 'SONY TV' as a second display. Under 'View HDCP status' it states that my craphics card and display are HDCP-capable.
