No picture after BIOS flash.
31 Aug 2009
Surrey, UK
I'd been getting some black lines with my 5770, so I decided to flash to the latest BIOS.
It's a PowerColor 5770 PCS+ and here is the BIOS I flashed to.
I used WinFlash, which said the new BIOS had been applied successfuly and asked me to reboot. Upon rebooting, and ever since, I don't get an image. The PC sounds like it's booting fine, but I can't see anything.
I've checked the cables and connections. Done a CMOS reset. And I've tried another PCI slot.
My mobo doesn't have onboard and I don't have a backup GPU.
I'm guessing I'm going to need some kind of DOS/boot utility from a pen drive?
Appreciate any help.
im no expert but have you tried resetting your cmos by taking the battery out for 10 - 15 mins
sound like its bodged up half way through updating
OK I managed to sort it.
Strangely, after updating to the new BIOS, the PCI-E power adapter off the PSU stopped working. I swapped it for a different 6-pin and it works, no matter what the BIOS. But when I plug in the original plug it doesn't show a display.
Maybe my PSU is on the way out.
