No picture in component
25 Jan 2003
Newark, Notts
I had a new TV earlier (tosh 32wlt66). When I first plugged the 360 into it via component it all worked fine. Now since then i've set everything else up (but havn't touched the 360 cables) and now im not getting a picture at all. I tried using normal SCART and the dashboard showed up, but when I plugged it back into the component ports again, no picture. I've switched the flicky thing to HD so its not that.
Any ideas? I've flicked through all the channels and its not showing up :(
Have you made sure that the switch on the side of the video cable on the back of the 360 is definately set to hd?
Dan.
fixed. for some reason plugging my GC into the ports on the side of the TV overrides the component. So when i unplugged that its fine.
Bit annoying really, anyone know if there's any way to stop this from happening?
