Hi there
I'll start at the beginning. I have recently been having issues with my swiftech h220, weird pump noises. Hoped it would be just air bubbles, took it off and on multiple times, shaked, replaced the coolant etc. Throughout this process I ran my pc without any heatsink on the cpu(i5-760) for periods of maybe 5 seconds each a few times. After multiple hours I gave up and decided to send it back since it's still on a warranty. I reinstalled the h220 so I could request a return online (issue with the pump did not impact temperatures), while doing that, I took off the gpu to connect an extra sata cable to my 3rd hdd, that I have not been using simply cause I did not have enough cables lol (extra cable arrived recently). After doing all of that I boot and everything works fine, I even played a game for an hour. Eventually I wanted to get the h220 ready for return, uninstalled it, put the no-name air heatsink on that I haven't used for almost 2 years boot and boom, no post. PC turns on for between 5-7 seconds, all fans spinning including the cpu fan but it then shuts down and repeats the process. Took heatsink off, cleaned the cpu from any thermal paste, made sure there is no compound on the motherboard or anywhere it should not be, try again, boot it, same issue. Tried putting h220 back on, same issue. Did not touch the rams or anything else, except the gpu and plugging in an extra sata cable but pc booted afterwards, I am really lost. GPU lights (evga gtx 770 classified 4gb) come on for the same duration, fans spin as I said. As far as I can tell my motherboard (P7H55-M SI) does not have the required pins for the system speaker, can anyone confirm that? Also, is there any way around that, installing an external one even though the mobo doesnt support it? Sorry about the chaotic block of text and if you got this far, thanks for your time!
Motherboard: P7H55-M SI
CPU : i5-760
GPU: EVGA 770 Classified 4GB
PSU: Corsair AX850
Thanks in advance.
CPU : i5-760
PSU: Corsair AX850
Thanks in advance.
