i have a water-cooled HD4870x2 that i think might have died.
I have had a run of graphical glitches over the past week. then my PC started failing to boot.
reset CMOS and could only boot into windows in safe mode (graphical glitches and BSOD) in normal mode.
noticed that windows had done an update to put it down to windows deciding to install a dud driver. so restored to few days ago, installed correct driver.
everything was fine for a few days. then same again, this time I looked at re-setting the card to insure it was in the slot ok. kind of got it working after a few attempts restarting CMOS, pulling the power cable out etc.
now i can only periodical boot into windows. most of the time it wont post at all (no beeps from speaker).
on the occasions i can boot into windows i get graphical glitches etc 98% of the time, the other 2% of the time it crashes after a while. if boot into safe mode eveything looks ok but then on reboot i get no display and no beeps. this confuses me as the card was working less than 10 seconds ago?
if i remove all power from the card i get beeps that corresponds to "no GFX detected" and then"component failure". if I put the power back in and remove the memory i get the beeps for "no memory detected"
so i think the motherboard is ok. and maybe the card is dead?? have completely removed my overclock and still no joy.
don't know why the card would have died, and it works ok in safe mode? will be getting another GFX card to test the motherboard in he next few days
full system spec
p6x58d-e
i7-930 2.8GHz
Corsair XMS3 6GB (3x2GB)
750W Corsair Modular PSU
2x75gb raptor (raid 0)
Quick update: have managed to boot into windows 7, install up to date drives. even played a bit of HL2. so the card must work. only have 2GB of ram installed. am going to try and reboot and see if it still works
full system spec
p6x58d-e
i7-930 2.8GHz
