No POST, beeps or anything much....***UPDATED***
Hi all ( - this first post edited....)
I RMA'd my board (system as in my sig...) after turning on my machine last week and getting a series of long constant beeps during the POST which according to the manual, indicated a GPU faullt....
I replaced the Radeon HD3850 with a passively cooled HD2400 and got the same beeping error tone!
I assumed it was faulty and after a call to OC's tech support and describing the fault and measures taken, got an RMA number and sent it back.
However, I got the board back today saying no fault fouund, board fully posts!!
Great, here we go I thought.
I put everything back together again, switched on.... but now I don't get ANY beeps at all - infact, it appears to momentarily spring to life when pressing the power button, but almost immediately (within 3-4secs) switches off and tries to restart, and continues in a loop doing the same thing.
Watching what's happening inside the case, reveals that the exhaust fan at the rear of the case spins up instantly, followed for a split second by the coolers fan, but then it's switched itself off again and attempting to restart over and over.....
I've tried one stick of ram, swapped them over so the other stick is in on it's own, but still got the same result.
My thoughts:
Dodgy power supply or maybe a fried CPU (even though it's clocked, it idles at about 46*C with about 58*C at full load - which is only ever for short a period anyway...)
Any other suggestions...?
EDIT: (plz bear with me a bit as it's doing my head in ....)
I must've put the HSF on skew-whiff coz after re-seating it and re-applying the paste, it stopped the cycle described.....and posted...BUT (read on plz....).....after replacing the mobo into the case and retrying succesfully and posting OK, added all the bits and bobs one at a time untill system was back as it was before all this pallava began!!
Everything ran fine for about 10-14 days (at stock).....then one night, the graphics/monitor started displaying a purpleish hue on everything when just browsing the net normally!
Restarting things never rectified it and as it was late, decided to investigate further in the morning!
Come the morning....no post....beeping as before.....back to square 1
I've just started troubleshooting things again.
I've unplugged all HDD's so just got GPU, RAM, CPU-HSF, K/B&Mouse plugged in.....(inside case)
Same beeps.
Tried alternative (known good) PSU...with the same result (one thing here....the beep code goes 3 beeps (pause) 8 beeps, and does the 8 beeps 5 times, then shuts itself down for about 5 secs, restarts, 3 beeps (pause) then continues beeping infinitely......)
Re-connected original PSU which then produced the same beep pattern!!
I'm thinking intermittent mobo fault as I've read reports of similar beep codes with this board after working flawlessly for weeks/months.....which could explain why the board posted OK for the RMA rather than some hardware of mine having an intermittent fault too!!
Before you suggest these things, this is what I've tried....
mobo outside of case....with case speaker connected
Mobo,1 stick of alternative ram in slot 1,original GPU, kb&m - same beeps
Mobo, 1 stick of alt (& later, orig) ram in slot 1 (and also) slot 3, alternative GPU kb&m - same beeps....(see why it's doing my head in??
To me, everything points to a dodgy mobo....but I've RMA'd it once and they've said it was OK.....bit stuck as to my next move....
Any ideas?
Ta peeps.....
My thoughts:
Same beeps.
)To me, everything points to a dodgy mobo....but I've RMA'd it once and they've said it was OK.....bit stuck as to my next move....
Any ideas?
Ta peeps.....
....though to be fair, it's been solid at my sig specs for 12 months, but looks like it was pushing it a bit too far, tbh!!
