Hi Guys so i have this weird problem,
PC SPECS:
MOBO:MSI Z77a-g43
CPU:I5 3570K
GPU: GIGABYTE 4GB OC 1050ti Dual Fan
RAM: X4 4GB all Same timings and production
So i have stumbled into this issue yesterday as soon as i installed the graphics card bearing in mind it was inside another RIG in my house previous to this and worked as intended,
So i installed the GPU went to boot perfect everything fine except from google Chrome being black which is a known issue, so i went and installed brand new drivers to see weather that would make a difference, after installation i restarted the PC but this time no Post just stuck at Bios Splash screen, With all Following options such as Bootable Devices DEL for Bios and F11 for Post, non of these options do anything except from entering bios takes me to a Black Screen with a white underscore at top left But instead of flickering its also Frozen,
POST does the same thing but the dash is in the middle of the screen, and bootable devices allows me to choose one, however once i press any bootable device the whole PC freezes again. Ive checked all connections to new GPU everything is fine .
I have also checked the ram sticks -- with one inserted it does the same thing, however with none inserted the screen never turns on but computer goes into a 10-15sec Boot Loop. i have checked different Ram sticks but same issue,
So Far i have unplugged all components so just CPU and Mobo are left same issue occurs, i have also gone and cleared the CMOS and shorted the two clips out with PC fully unplugged but same issue occurs, i have connected a different PSU still same issue and finally i have also tried plugging a Different SSD still Same issue, ive done loads of googling but nothing seems to come up and if it does the threads are never fully answered.
At this moment in time im really stuck and i dont know what could have Happend Any help would be greatly appreciated as there is nothing i can physically click or access without PC hanging
KIND Regards
Dan
Id also Like to add that when i boot In bottom right it says sometimes A2 or A9 or A0
PC SPECS:
MOBO:MSI Z77a-g43
CPU:I5 3570K
KIND Regards
Dan
