No POST or Beep error
20 Aug 2008
Just today assembled a PC that I have made out of spare parts.
Mobo: Asus M3A32-MVP Delux
CPU: AMD Athlon X2 2.4GHz (Model# AD04400IAA5D0)
RAM: Kingston 677mhz DDR2
HDD: WD Velociraptor
GFX: Nvidia 8400GS
The problem I am having is that I am getting no signal on the monitor and no beep error codes. I have the chassis speaker pluged in and know it 100% works as I have tested it.
I have took the PC out of the case and rebuilt it on a table and still the same thing happens. The HDD indicator flash's once every 2 seconds which is odd.
I have done the usual steps of adding one component at a time and still the same thing. The thing is that I know all the parts work as they have come form other working systems, any ideas?
Yes I gave that a go as well. Tried a different monitor with a different cable and same problem. And I know the monitor works as It runs another PC :(
