No Post
17 Jun 2018
Just installed a new Gigabyte ab350 gaming edition with a ryzen2600 and 8gb memory made sure to plug everything on checked twice but I get nothing showing up on the display, gpu lights are on (r9 290)but the only light I see on the motherboard are the LED nothing else, any help would be welcome thanks in advance
B350 boards need a BIOS update to take Ryzen 2600. If the BIOS on that board isn't new enough, and that's the cause, you can borrow an earlier Ryzen CPU to do this, or send it back to retailer, or ask Gigabyte to collect your board and do it (if they still offer that service).
@Kleanthis
should be able to either request boot kit from AMD , @AMDMatt should be able to help with link, cant remember (Not sure if GDPR effects or makes process a little different then before)
or Gigabyte UK should be able to arrange a flash , but believe you'll have to cover the postage costs @GIGA-Man (Not sure if GDPR effects or makes process a little different then before)
