Right, to cut a long story short, whilst waiting the next gen of GPU's I thought I'd tide myself over by adding a second 5870 to my system...
Turns out I didn;t have enough PCI-E connectors nor, probably, power on my current 650W PSU so I bought an 850W Corsair with the required number of connectors.
So I lay out the PC on a desk, remove the old PSU, plug in the new. Check everything is seated correctly, power on. And nothing, no lights on the mobo, no PSU noise, nothing.
I triple check all is connected. It is. I try again and the same result. So I suspect a failed PSU.
Which is annoying but not the end of the world. So I unplug the second 5870 and reconnect the old PSU, check all connectors again and get the same total lack of repsonse. Which is now a bit of a concern...
I have no idea what I could have omitted, or how a critical component could fail during a simple power unit swap out. I've tried different power cables and different wall sockets to no avail. I've checked all components and all connecitons are firmly seated and now have no idea what to try next..
Any help will be much appreciated although I'll not be able to implement any advice offered until I get back to the PC on Thursday..
Thanks!
Mike
Thanks!
Mike
