So I just ordered most of a new PC. Here is what I bought:
http://www.overclockers.co.uk/showpr...odid=CP-418-IN
http://www.overclockers.co.uk/showpr...odid=MB-391-GI
http://www.overclockers.co.uk/showpr...odid=MY-114-GL
http://www.overclockers.co.uk/showproduct.php?prodid=GX-049-HS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-055-AK
So I just put it all together inside my HAF932 case and I thought it was all set, then when I turn it on nothing happens. Absolutely nothing.
Now I have done this before, though it has been a while so it is possible that I may have done something wrong. However I have connected the 24 pin power, the 4 pin power for the CPU, both the GPU power cables and 1 cable each for my optical and hard drive.
I have connected the front panel as well. I know I have put them all in the right place. However there is one wire I have not seen before and which is not present on my case. This connector is called: MSG/PWR (message/power/sleep). Could not having this be connected be a problem? Is there any way to test the power switch (what would happen if I connected the reset button to the power would pressing reset turn it on or would it break stuff)?
I have tried my old PSU which was enough to power up my old broken motherboard and exactly the same thing happened.
I am about to test using only 1 RAM stick and after that using only the on board graphics.
If anyone has any ideas at all then please enlighten me.
