2008 homebuild: Asus Rampage Formula, Q9650, 4GB DDR2, W7 x64.
This has been running perfectly since I built it. It was lightly o/c to 3.9 GHz but since the problems arose I'm running at stock 3.5 GHz.
The issue is that the machine fails to power up until either an external USB drive is attached, or the CMOS is reset.
To try to fix this I have done these:
1. Renewed CMOS battery.
2. Thoroughly cleaned out all dust, disconnected all cables and cleaned pins, removed and reinstalled memory sticks, checked start connections on mobo and case.
3. Switched SATA cables to different sockets.
4. Checked BIOS boot priority.
5. Disconnected PSU and checked using the paper clip method - the fan runs normally.
6. Installed a different graphics card.
None of these has corrected the fault. When I reset the CMOS or attach an external USB drive the PC 'appears' to start and boot normally but clearly there is something very wrong somewhere.
I have run out of ideas and can only assume some major motherboard fault.
Before I junk this rig, I'd be grateful for any suggestions as to what the problem might be.
John
John
