After a week of delays and problems, I finally received my new system on Friday. The first good system I've had in a long time. I got to play with it mostly on Saturday and it was working (for the most part, only one weird crash and a weird buzzing sound, but that's all, and the buzzing stopped).
This morning I switched on the machine, it began booting for a split second and then shut off. Since then, it will not power on, much less boot.
Now anytime I plug the thing in and switch on the power (at the back) there are two lights that flash on the motherboard. There are two silver buttons, one has a red flashing power symbol, the other flashes green 'reset'. They flash together, but slightly out of sync.
When I push the power button at the front to start the machine, nothing happens.
No where on the internet nor in the manual for the motherboard does it tell me what this means. All i know is, it's broken
I would appreciate any help anyone can offer, although I have a feeling the end result is that it will have to go back to be repaired, it's not even three days old :"(
Thank you
Edit: This is my system http://www.overclockers.co.uk/showproduct.php?prodid=FS-174-OE although the power supply is upgraded to 1000W, I got the SLi option, and the overclocking doesn't work, in case that is relevant.
Thank you
