Hello,
My PC isn't powering on. Was working fine up until I switched it off at 4 this morning but when I got up today it isn't powering on at all. I've tried the paper clip test to see if the PSU is at fault but its powering up ok so I guess that's ruled out. Have also unplugged everything from the motherboard apart from the CPU and cooler and am still getting nothing.
When I switched it on this morning, the lights on the front came on for around half a second before switching off and powering down.
I suspect my motherboard is faulty but wanted to ask if there's anything else I should check before I send it back. I can't see a power led on my motherboard (don't think there is one).
Specs are:
Gigabyte Z77-D3H
i5 3570k
8GB RAM
Enermax 500w PSU
Gelid Tranquillo
Any advice would be appreciated.
Thanks,
Specs are:
Gigabyte Z77-D3H
i5 3570k
8GB RAM
Enermax 500w PSU
Gelid Tranquillo
Thanks,
