For about £45 you can get a squat stand/rack rated to about 180kg, I have one at home, works great. You just don't have safety bars like a proper rack
I wouldn't recommend them.
Used them before and you need to be really careful not to knock them over when putting the weight back.
Maybe it's just me as I tend to collapse forward into the rack when finishing a particularly hard set.
I was thinking
Clean + press
Front squats
Bent row
Dead lifts
Everything covered with that?
Lunges a good so l swap for split squats,? Never got on with them in the past.
Heavy snatches have always annihilated my quads too. I quite like them from the hang position as you never unload them.
Probably because you are not using your posterior chain properly and coming up onto your toes too quickly.
As exercises go, heavy snatches are not something your average gym person can do and are pretty poor for strength/hypertrophy by themselves.
What? You generate the power for the lift with your hamstrings and upper back? Glutes alone certainly can't do it.
No exercise is effective by itself. As for increasing strength it's an absolutely excellent lift. And who cycles hypertrophy exclusively (if they know what they're doing)?
Cleans have been suggested here too and they are most definitely not suitable for an "average gym person" either, whatever that means.
Not quite what I suggested.
And most people do cleans badly but doing so isn't inherently dangerous as they can't badly clean enough to really injure themselves (very generally speaking). Exposure on the snatch, however, given a lot of people have some form of shoulder dysfunction or reduced mobility, is significantly greater.
I love the snatch as an exercise, but my mobility is significantly better than most, and - like you, I suspect- I have had a lot of formal coaching with my lifting... most non-Olympic lifting athletes who use it do so as an explosive power optimising exercise which is what it is absolutely for... and having tried encouraging people on here to start snatching (with some success... but the sample size was too small to really be indicative), it is not something I would encourage people to really try unless hands can be laid on them (as such).
