Hyundai getz 2004 model.
The other half got told that she had no rear brake lights on the car so I have had a look at it today.
common search is the brake switch not working.
- Checked fuses - 10amp fuses and all fine. one for left and one for right side.
- removed brake switch to test and this is fine, created a circuit with batteries and a bulb in. when plunger out the circuit was complete and light came on when pushed in light was off.
- rear lights come on when head lights are on as normal just no brake lights when brake pedal pushed.
One thing I did try was bridge the connecter that plugs in to the brake switch and I still had no lights, my understanding is if I did this the lights would come on but nothing. I used a bit of cable from a hoover that was going in the bin.
Can anyone suggest anything else to try before I take it to the garage Monday? there is also a light in the middle of the rear window at the top which also does not work.
thanks!
thanks!
