No 'Send to' Option?
19 Oct 2002
Maidenhead
Just installed XP64 and it doesn't have the 'Sent to' option.
I can see the 'Send' to folder in each user, anyone know how to fix this?
Cheers
Administrator
I had some problems installing it, the initial part of the install when its copying files across before it reboots, mine took about 2 hours! But rest took about 10 minutes :confused: I think my dvd drive is on it's way out :(
Apart from this rather annoying problem im really impressed with XP64, ive not come across one piece of software that wont install :D
