- 9 Jan 2010
Hi there, left my pc on last night as windows was installing updates so let it run and shut itself down. This morning I came to turn it on it loaded the welcome screen then just turned off went to turn it back on and it's making all the right sounds the fans turning on etc but nothing on the monitors checked the monitors on by connecting to my dvi port on my laptop both work fine. Disconnected the monitors and reconnected them to get the same message 'no signal detected'.
Opened the case and checked Ll the connections were tight closed it and tried with jus mouse, keyboard and monitors still no luck, gave it a goggle and the too major suggestions were replace motherboard and replace graphics card. Any other ideas or suggestions would be most helpful.
It's a self built pc the board is a P5Q PRO and the card is an ati 4850, windows 7
