No signal detected
28 Jun 2014
I've just built my first pc in a mini itx form factor but after having made sure that everything was plugged in as far as it would go, when I plugged the motherboard into my 21:9 monitor using both hdmi and dvi neither seem to have signal on the monitor however all the fans, the optical drive, the front panel io and the cpu cooler do seem to be working. Please could someone help and ask if you want more specifications.
more spec will be required.
mobo /cpu/ram etc
More than likely it could be out dated bios. might have to update this buy using an older cpu
Have you connected the 8Pin EPS to the motherboard from the power supply?
I have i5 4690k, msi z97i ac, corsair 2133mhz vengence pro, corsair 100i, amd r7 265.
Oh ond in that place is inly a 4pin cpu connector not an 8 pin
