hi all
my boys pc is having a few issues he is getting no signal detected when he turns on the pc
its been like it for a few months now some times it works some times it wont he was using a gtx 560ti that i took out when the problem started and he was using the onboard graphics but was still getting the same problem
i had a look today i i took out the battery to reset the cmos when i started it up it booted to bios so i set it to onboard graphics saved then it restarted and got the same no signal detected
any help would be great
cheers Nathan
Asrock H61 Pro Socket 1155
early i3 not sure what one
1x 8gb of ram
cheers Nathan
1x 8gb of ram
