- 12 May 2011
- Southampton
My PC has a Nvidia 450 in it, which works fine. But when I put my 7970 in, it doesn't reach the post screen, I just a blank screen (Monitor doesn't detect any input) and no beep from the motherboard. The GPU fans spin up.
The Motherboard is a Foxconn H61MXV (it was free!) running the latest bios. Power supply is an OCZ 500Watt (not great, but the recommended Wattage PSU for a 7970) which has the required 8 + 6 pin connectors.
The only problem seems to be that the PCIE slot is 2nd Gen, when the GPU is 3rd Gen, but they should still be compatible...
It does the same thing with a 390x, which i know for sure works.
An 8800GT works fine in the PC
A 4850 works fine in the PC.
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000522
